formula labview 8.5
hello,
I have installed labview 8.5 base development but I cannot use the formula vi, I don't know why?
I have a blank window as in the picture, is this a LV8.5 bug?
thanks for help,
(3,513 Views)
Interesting...
Does it still happen if you open a new VI and then place a formula express VI?
(3,502 Views)
Yes, it does.  This is a known issue with the 8.5 Base Development System, I appologize for the inconvenience.  This was reported to R&D (4EFEMMWB) for further investigation.  See here for more info:
(3,478 Views)
Thanks for the info.It is  wierd this issue.
When I tried to reload the same code in  another computer I have to redo the same exercise meaning load the formula vi from the NI program file\lib ....it is really not handy.
On top of that I have many problem since I have installed LV8.5 (see pictures), the program crashes all the time.
Is there anyway to avoid this???
thanks for advise.
(3,408 Views)
