formula node: Else if
I want to use a formula node to make my code smaller.
I'm comparing a sensor value and depending on the value i have 3 options.
At the moment i get the error that labview thinks my 'Else if ' is a variabel instead of a command.
am i doing something wrong? another option is to use a Case-structure but this code is allready in a case so i don't know if this could give trouble.
thanks,
Lars
(7,169 Views)
Hi Lars,
what about 2 3 statements:
Set output values to default values (aka last ELSE part)
IF x < y THEN set values (aka first IF part)
IF x > y THEN set other values (aka second IF part)
 As this example:
Why don't you use a case structure?
 And keep in mind the limited resolution of floats when comparing them…
(7,159 Views)
Still Overkill with the CPU overhead why not: (VI attached in 2010 for compatility)threshold.png
Bah - you edited after just before I posted Gerd - there was no Pic there before!
James
CLD; LabVIEW since 8.0, Currently have LabVIEW 2022 SP1 installed
(7,150 Views)
Or without any case structure (and without non-typedef'd enums 😉 😞
You just have to put the correct numbers into the array constant…
(7,144 Views)
Elegant Gerd, Scalable (and I would have typdef'd If I was keeping myself) but much less readable and unable to add e.g. a String to the same array - then the BD starts to get messy again.
Waiting for Christian to post with 1 compare function using a complex number that makes even your look big and a Rube!Smiley Very Happy
James
(7,131 Views)
Hi James,
when you want to mix datatypes you go with an 1D array of cluster and unbundle instead of the 2nd IndexArray…
My own idea:
Just one comparison… 😄
(7,128 Views)
good point
Yesterday I needed my eyes tested for failing to see a comma,
now I think I need sleep for failing to think of the ovbious!
(Still waiting for Christian's wizardry though. - I don't think your is a Rube but he has a horrible habit of making thing that look simple like that even more simple!)
James
(7,124 Views)
