formula node output on the right hand side
The equation as posted by altenbach can be solved explcitly for x.
Isolate the sqare root term. Substitute y = 1/x. Square both sides. The remaining quadratic equation in y can be factored giving two solutions:
y = 0
y = -(f - a*c/b)/(f^2 - a*c^2)
Lynn
Message 11 of 13
(1,038 Views)
I am sorry if it is not in the preferable format for you
Message 12 of 13
(1,019 Views)
Thank you Lynn for the math work.  Quickly checking the math you are correct the the equation can be simplified as quadratic equation and solved but the constant need be double checked.
However, I read you post after making my way around the problem and I am interest to see it working. I used string concatenate to write formula string and zeros and exterima to find the zeros. The code works but gives results the most stupid high school student will never give. If you do not mind have a look
Message 13 of 13
(981 Views)
