formula node: "integer type required"
Hi all.
I'm having a small problem. It seems so easy but I can't reach there...:p
I'm just doing this formula in the formula node:
Y=10^((0.001-32.44-(20*log(2400))+X)/20);
where X is the input and Y the output. Of course that the result won't be a integer, but how can I solve this one?
Message 1 of 17
(23,734 Views)
An integer type is required when you do a '^' operation. That's a bit exclusive or. If you really are trying to do exponentiation, use the '**' operator.
Message 2 of 17
(23,729 Views)
Right. Is that the problem.
But I do the same with:
pow(10,((0.001-32.44-(20*log(2400))+X)/20); right?
Thaks
Message 3 of 17
(23,726 Views)
You can do Y=10**((0.001-32.44-(20*log(2400))+X)/20); or Y=pow(10,((0.001-32.44-(20*log(2400))+X)/20));
The one you just posted needs another right parantheses.
Message 4 of 17
(23,721 Views)
I'm getting the same error. However, my formula is very simple. I'm just starting to learn to use labview and i was trying to get the idea of how the formula node works, i cant figure out this error though.
Message 5 of 17
(23,683 Views)
Try x**2+x+2 per Dennis' first suggestion.
Message 6 of 17
(23,679 Views)
Hy! I am a rookie and i have a kind of a problem with the formula node ... same as others here is the ecuation: "x^y=z;" and i recevie this error: "FORMULA NODE: integer type required". I try do do it with x**y=z but i get this error: "FORMULA NODE: Missing semicolon". I am new with this program ... so take it slow ... THX 🙂
Message 7 of 17
(22,961 Views)
@SparX In your first formula you end with ";" in the second it's missing, could that be it?
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 8 of 17
(22,959 Views)
I forgot to put it in the last post .. but is not missing from formula node:
Message Edited by SparX on 01-09-2009 05:09 AM
Message 9 of 17
(22,956 Views)
You need to turn your expression around, so it's in the form of output = function of inputs
In your case, z=x**y;
_____________________________
- Cheers, Ed
Message 10 of 17
(22,949 Views)
