formula node
Hi.
Question concerning formula node:
I need to perform the following pseudo code, but I did not quite understand the formula node syntax. I have two inputs, finish and tab, with output n_tab.
if (finish=1 and tab=1)
n_tab=4;
elsif(finish=1 and tab=4)
n_tab=14;
elsif(finish=1 and tab=14)
n_tab=15;
elsif(finish=1 and tab=15)
n_tab=19;
else
n_tab=tab;
(2,921 Views)
Hi
Have a look at the attached vi.
Hope this helps.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(2,917 Views)
Thanx. Should have known about the == and not only =   Smiley Wink
Easier to ask stupid questions than to read the manual....
(2,911 Views)
