formula node
Is it possible to connect boolen control and indicator to the input and output terminals of formula node ? If yes pls explain me with VI.
(3,240 Views)
Don't create a duplicate post under a completely different username.
Stick with your original post where you were already helped.
http://forums.ni.com/t5/LabVIEW/is-it-possible-to-connect-boolean-control-and-indicator-to-the/td-p/...
(3,238 Views)
