formula node
Dear Friends
I would like to calculate rms value of my square wave pulse Arrays in a formula node based in C code
Any Ideas please
(5,287 Views)
Hi rumayan,
does it have to be C?
Why not use LabView:
(All the functions can be found in the math/statistics palette, at least in LV6.1 to 7.1.)
Message Edited by GerdW on 08-03-2006 10:46 AM
(5,282 Views)
Dear GerdW,
Thanks for reply. Yes, it must be  C code because it is a part of a big program.
Alternatively,  if I could write the root mean square formula(rms=sqrt (1/n((X)^2) as a C code that great. Because then,  I will be able to define it as a variable
Any Ideas Please
(5,264 Views)
I'd say that the LabVIEW method is by far the easiest, as the example above shows. However, since you say you need it in C, while you could use a formula node, you're probably better off creating a DLL since you say this is part of a larger C program. Can you simply add the rms function to your C code and compile it into a DLL? That way you can call it from LabVIEW. If you look in the manuals that ship with LabVIEW there's one devoted to calling external code, and there's an example that ships with LabVIEW that's very good in showing how to do it.
(5,244 Views)
Dear friends,
Is there any way to generate a square wave inside labview with different rise times?
(5,170 Views)
Hi rumayan,
you need 'square wave with different rise times' ??? Square wave should have an infinite small rise time...
So you probably need something like a saw-tooth. Generally, a wave is just an array of values over time. You can define any kind of values! And there are even functions to generate waveform (sine, square,...) or ramps: look at palette 'signal processing' -> 'Waveform generation' or 'Signal generation'.
(5,164 Views)
thanks a lot that was helpfull
(5,150 Views)
