formula node
Hi everyone.
I have a problem with the formula node.
I want to calculate the following  function:
Ux=xdot+Omegat*(y-y0)+thetax
where xdot, Omegat, y, thetax are all 1D arrays ( honestly these are waveforms but I convert these in arrays) while y0 is a constant. Also the output Ux has to be a 1D array.
When I implement the formula in the appropriate box I receive a message about "array indexing indices".
For more information I link my .VI.
Some idea how to solve this task?
Second question:
Using the formula node is faster than realize all these operations in a different way?
I ask it because I will need to include this .VI into 5 different "for loops"?
matomato
(3,171 Views)
Hi matomato,
fastest is usually to use LabView primitives! See attachment...
Edited: made another small change to your vi: changed y0 to DBL to avoid unneccessary datatype conversions!
Message Edited by GerdW on 02-27-2008 05:11 PM
(3,162 Views)
Thanks GerdW!!
This means that it is better to use the primitives than the formule node.
Great
matomato
(3,150 Views)
