formula nodes
I'm using a Formula Node and my out put is always the number the same
Z= -4.08442104999969e-1*X+2.21688421e1;
the value of X changes
not sure what im doing wrong
thanks
Message 1 of 11
(5,654 Views)
Please attach your code or an image of the block diagram. You can do both by creating a Snippet.
Message 2 of 11
(5,650 Views)
Hi MCHCJWT,
funny as my solution seems to be ok:
And a formula node works the same as the expression node above:
Message 3 of 11
(5,647 Views)
I also question why you are using a formula node instead of the LabVIEW math functions.
Message 4 of 11
(5,644 Views)
To follow up Dennis' question:
Both use (more or less) basic LabVIEW functions…
Message 5 of 11
(5,635 Views)
Message 6 of 11
(5,632 Views)
ok, nice image…
What is wrong? Where do you get wrong unexpected results?
Can you attach your VI with some default data?
Message 7 of 11
(5,620 Views)
First i would to thank you for you help.  i'm very new to lab view and this was someone elses code that im using
i attached the vi.
Select semi rigid cable type should be 3
lenght 22
Message 8 of 11
(5,606 Views)
The numbers aren't always the same, but you're not looking enough decimal places, see the attached VI.
Message 9 of 11
(5,599 Views)
Hi MC,
change your VI to this:
and you will see in the XY graph ReturnLoss is changing with frequency!
Message 10 of 11
(5,597 Views)
