formular node
I  am trying to use the formular node.  There is a problem when I use the arithmetic shift right and shift left with formular node.  The result show differently with using the labview code when the binary number length is 31.  I attached the example.  I need some one help explain what I am doing wrong.  This problem also happen for orther operator  such as "or, and" I am using labview 2009.  the same thing also happen to LV 8.5
thanks
tphan
(3,583 Views)
Can you upload into LabVIEW 8.0?
(3,578 Views)
I don't have LV8.0 but I have LV 6.1.. Hope this works on LV8.0
Tphan
(3,565 Views)
This is still the same bug as this. I'm surprised it's still there in LV 2009. If you change your "b" variable to "int32" it should work.
(3,559 Views)
Hmm.  I would say it getting worse in 8.5.  Try this.  It working in LV6.1 but not in LV8.5  .  The formular mimics the rotation function in labview.  All the input is int32.
Tphan
(3,548 Views)
