fpga 9148 example
I have a 9148 chassis that has a FPGA, and I have a analog output and digital output modules.  Is there a quick way to find an example for that?  I am looking for some fpga code that would generate a analog or digital waveformr.  Thanks!
Kudos and Accepted as Solution are welcome!
(3,389 Views)
Hi, in case you haven't seen it here is a getting started. Regarding the code, simply type the module number at the NI Example Finder to find examples Smiley Wink
Alejandro C. | National Instruments
(3,373 Views)
I need a VI to run a motor continuously can u please help me??
(3,364 Views)
AJAYKUMAR, correct me if I'm wrong but it seems that you have a different problem. In those cases, opening a new thread on the respective board will enable the community to help you. I strongly recommend searching on the forums and the community before posting. Most of the times you can find answers, for example: Check this forum. Plus, you need to be a little more specific with your question, try to include hardware/software requirements and such.
(3,356 Views)
Continued here.
(3,345 Views)
