fpga: ERROR:sim - Input_Depth: Invalid value 'xxxx'.
Sometimes I'm getting this error:
LabVIEW FPGA: The compilation failed due to a xilinx error.
Details:
ERROR:sim - Input_Depth: Invalid value '536870912'.
ERROR:sim - Failed to initialize fifo_generator_v5_3 IP model.
ERROR:sim - Unable to configure IP model for generator
'implementation_netlist_generator'.
ERROR:sim - Failed to generate 'builtinfifocorefpgawfifon3'.
ERROR:sim:554 - Error found during execution of IP builtinfifocorefpgawfifon3
(Fifo Generator version 5.3
The error can occur when I make small changes to a VI.
The strange thing is that the disappears when a copy all the content of the VI to a new one.
Has anyone experienced the same thing? What could the problem be?
//Anton
(6,159 Views)
I got exactly the same error message today.  I have no idea what the error message means, but copying the entire VI into a new VI fixed the problem.
(5,989 Views)
Worked for me.
(5,901 Views)
Hey all,
We've seen an increasing number of customers report this since LV 2011 released, but have been unable to reliably reproduce the error in house since moving the project to another computer also seems to fix the error. If you do see this again, I want to inform you of a much simpler work-around. If you go to the properties page of each of your FIFOs, Change the "Control Logic" setting to something other than "Target Optimal". This has resolved the issue in other reported cases. Are any of you experiencing this issue in LabVIEW 2012? According to the CAR (corrective action request) on the bug, it should be fixed there.
Cheers!
TJ G
(5,889 Views)
My problem was/is happening in LabVIEW 2011
(5,883 Views)
This has happened to me before. What I usually do is delete the FIFOs (remove from project) and re-create them. Copy and pasting to a new VI or project as mentioned above works as well but I find it easier to just re-create the FIFOs.
-jeff
Jeffrey Lee
(5,770 Views)
-jeff
It works.
(4,933 Views)
