fpga VHDL import in Labview
I have to import VHDL code in Labview. I would like to know what is the best solution betveen CLIP, IP Node integration or HDL node of the previous version of Labview if it is possible to use it.
Thank you
(3,266 Views)
Accepted by topic author elie.deygas
I think those documentations will help you to choose, depending on your requirements:
Difference Between CLIP Node and HDL Node
CLIP and IP Integration Node Differences
Mathieu P. | Certified LabVIEW Associate Developer
National Instruments France
Journées techniques : des fondamentaux aux dernières technologies pour la mesure et le contrôle/comm...
(3,225 Views)
Hello
Elie D.
(3,199 Views)
