fpga asynchronous logic, Is it possible?
I would like to use the FPGA on my 7811R to route a digital input directly to the PXI_Star line without any clocking.  The signal I would like to route
is 25Mhz so would not be able to resample with conventional LV FPGA code.  Is this possible?  I was wondering if the IF-RIO async nodes would work
for this application.
(3,906 Views)
simple answer, no you can not route directly.
you can try to use a derived clock to go faster, but this will still have some latency
Stu
(3,893 Views)
Is there a technical reason why this isn't possible? It seems like you could probably lower energy consumption and minimize latency with asynchrous logic.
(3,729 Views)
The IO is hardwired to the FPGA.  So the FPGA would have to read it and then pass on the signal to the PXI STAR.
(3,721 Views)
