fpga bit file to debug mode
Open the configuration dialog box for "Open FPGA VI Reference" and you'll see the checkbox for "Bind to Type Definition."  See the help.  You may want to use a dynamic reference instead, if you're using a newer version of LabVIEW.  I haven't used that option yet but a post elsewhere on this forum from an NI employee recommended that as an alternative to binding a type definition.
Message 11 of 12
(383 Views)
I actually have the dynamic mode check, so the binding option is greyed out.  Thanks!
Kudos and Accepted as Solution are welcome!
Message 12 of 12
(379 Views)
