fpga bitfile generated and timing violations
Hi all,
 how is it possible that a bitfile is generated when there are timing violations. Is this bitfile still runnable and what problems can occure when you run it.
 I use labview 8.5.1
Regards
Frank
Message Edited by fengels on 04-28-2008 08:47 AM
(2,748 Views)
Not sure if a bitfile is generated when there are timing violations. It
might always be generated, or perhaps an old bit file is only deleted if the
new one is create. My guess would be it won't function at all.
Wiebe.
(2,663 Views)
Wiebe,
 Thanks, Something stange happend here, perhaps the old bit file has been run.
Cannot reproduce it, so problem is "solved" 😉
regards
Frank
(2,647 Views)
