fpga compilation error NI farm
I have a NI compact rio 9082 setup in my lab. I am running labview 2019 SP1 and was trying to compile the example for NI9237 for getting strain data. While compiling the "NI 9237 Getting Started (FPGA).vi" i am getting error message. I have tried both local compilation and cloud compilation, but both failed with different error message. I am using the farm server for labview 2019 and have login to the "http://localhost:3580/login" with  confirmation message "Logged in as: admin". I have attached the snapshot of the errors. For local compilation the error is "This version of the NI farm client is not compatible with the specified server.", while the cloud compilation error message is "Cannot communicate with the specified protocol. This version of the NI-Farm client is not compatible with the specified server. The port 3580 is open and working for labview and doesn't have any conflict in the firewall.
(957 Views)
I've had the same issue running the same version of LabVIEW. Only thing that worked so far is repairing the LabVIEW FPGA Compile Farm Toolkit in the NI Package Manager. If someone has another (quicker) solution, it would be appreciated.
(842 Views)
