fpga compile error expression has 93 elements expected 50
I adapted the project found here http://www.ni.com/white-paper/11249/en/  to my need,i.e. a sbRIO 9636 instead of the sb9631. I renamed the I/O, FIFOs and changed the VI references in the subVIs manually. Apparently, everything is configured the same but my project does not compile and I get the error message "...expression has 93 elements expected 50..." cf. attached picture. I suspect a problem in the FIFO configuration but it is just a guess. Can you help me? Thanks
(2,926 Views)
Hmm...
I would start by forcing LabVIEW to recompile the entire FPGA VI hierarchy. Go to your top-level FPGA VI, and hold down <CTRL> + <SHIFT> while you press the run button. If that doesn't work, I would delete and recreate any FIFO/Memory/Register access nodes in the VI Hierarchy. I think you can find them using <CTRL> + <F>.
Cheers!
TJ G
(2,916 Views)
recompiling did not work but recreating the FIFO access nodes helped. Thanks for your help!
(2,887 Views)
I am facing the same issue but with a different hardware, sbRIO9606.
I tried with <CTRL> + <SHIFT> while I press the run button and delete and recreate any FIFO/Memory/Register access nodes.
But still I am getting the same error.
Its very difficult to trace the error as the error description does not point any location in the VI.
ANy help is appreciated!!
Yogesh
(2,808 Views)
