fpga compile server does not compile everything!
Hello there!
I've made a very easy Labview FPGA VI. And sometimes the compiling process finishes without any problem.
But if I use a comparison like "bigger than" ther comes only the following message.
Release 7.1.03i - Xilinx CORE Generator IP_H.16
Copyright (c) 1995-2005 Xilinx, Inc.  All rights reserved.
Regenerating IP...
   the output directory. Output products for this core may be overwritten.
Generating Implementation files.
Generating the VHDL instantiation template.
Generating VHDL structural model.
Finished Regenerating.
Successfully generated core_prim_gt_0003gtsigned16.
After that the compile server shows the message "idle.." without any error.
I am a beginner in programming with labview. How do I compile a VI? Perhaps I'm doing sth. wrong.
My Labview version is 8.0.1 . I recently updated because I thougth that could help.
Thx for every help!
(4,339 Views)
I also have this problem.
The compile server were holded with idle status if I have any comparison function in the program.
Can anyone help?
(4,259 Views)
When you use the comparison functions the Xilinx Core Generator is invoked.  There is something going wrong with the Core Generator.  I have seen problems in the past with language settings and core generator.  Do you have any non-english language settings for the OS or LabVIEW.  In particular, I think the option to use a comma versus a decimal point has caused issues.
Joseph D.
(4,250 Views)
Hi, thank you very much for your reply.
However, I don't use anyother language besides English on that computer.
So do you know what I can do for this problem? Hope for your reply, thanks!
(4,237 Views)
Hello there!
I found out my problem and after fixing it, everything was running without any further failures.
LabView needs for compiling administrative privileges on the folder C:\programs\LabView.
LabView always saves the temp files of the compiling process. So the compile dosn't work if
you don't have acces to this folder.
I hope I could help you a bit.
Live long and prosper!
(4,191 Views)
Thanks you so much!
I really don't have the administrative access for the folder.
I will try it! Thank you!!
(4,173 Views)
