fpga crio Vibration template error code 63192
Dear all,
I'm using the crio vibration data logger template and i'm seeing the error code 63192 from the FPGA reference from the DAQ Thread.vi
Please can anyone help with this error message ?
I've re-compiled which hasn't solved this issue and looking up the error code doesn't suggest much else.
Cheers
(3,150 Views)
Please see my project too ensure i haven't made any stupid mistakes. I've made it into a zip as it has included sub vi ect.
Cheers
(3,142 Views)
Hi all,
Customer support pointed me towards a knowledge based articule here
It was suggested the names did not match up from the project and in max. Please see below that my names match up fine. Also as already mentioned i've rebuild the fpga.
Any thoughts from those experienced users ?
Cheers
(3,128 Views)
Did you resolved the problem?
(2,539 Views)
For those interested, I had a similar problem and it was a name mismatch between the cRIO FPGA in my project and the actual cRIO FPGA name in NIMax.
(709 Views)
