fpga digital and analog out
I am writing a digital and analog output program.  The digital pulses should run concurrently with the analog signal.  But when the length of the analog signal equals the length of the digital signal, the analog wave is misalligned, starting with the first off (when it should start with the first on).  Then, even weirder, if the analog signal is just shorter than the digital signal, the analog wave will slowly shift to where it should start.
This program is being run on a 7833R chip.
Thanks for any help!
-JP
Message 1 of 1
(3,233 Views)
