fpga error 305001
hi friends ,
I have this error so i m using labview 2009 on Windows8 -64bits  i can't run my Vi on NI DE FPGA Board connected on an Elvis II+ so what is the solution and thanks for your support
(2,651 Views)
Hi Moujahid,
I think I should mention a couple of things; first, according to this Knowledge Base Article and this white paper, LabVIEW 2009 is not compatible with Windows 8 64-bit; the earliest compatible version is LabVIEW 2012.  While it could be that LabVIEW 2009 has some functionality that works, we cannot guarantee that all functionality of LabVIEW will work on Windows 8.
That being said, it looks like you have a connection error with this board, have you tried connecting it to another PC?  If you have LabVIEW 2009 SP1, can you connect the board to a machine running Windows 7?
David B
(2,592 Views)
