fpga power on reset
I have a PCI-7833R. The FPGA is programmed, so that it would supply two digital high constantly.  We had a power outage, and the FGPA was foced to power down.  When I turn the power back on, the FPGA was no longer supplying the two digital high.  I have the following questions:
- It seems to me that the FPGA VI was not running at all after power down.  Shouldn't the FPGA always run?
- For example, I have a brand new FPGA, and I run an application with FPGA VI, host VI, and bit file.  After that, I let the FPGA runs headlessly.  I assume that the FPGA took on the personality from the bit file of the application that I ran previously.  If that's the case, at what part of the application does it associate the bit file to the FPGA?
- If I don't have the FPGA module in my LabVIEW, and I receive a bit file from my co-worker, How do I associate the bit file with my FPGA, and have the FPGA runs headlessly?
- After a FPGA is configured to have the personality of a bit file, What are all the ways to clear that or corrupt that?
- If I have a FPGA that is running headlessly, and I want to do a reset, so that the FPGA runs from the start again.  Is power cycle an option to do that?  Are there any other options?  Can I reset a FPGA without power cycling it?
Thanks!
Kudos and Accepted as Solution are welcome!
(3,558 Views)
(3,544 Views)
Accepted by topic author jyang72211
No.  The FPGA loses its configuration when it loses power, and must be reloaded in order to start again.  In most FPGA systems (not just NI) this is done by keeping a copy of the configuration in an EEPROM or similar and loading it at power-up.  Some NI FPGA cards allow you to download a bitfile to the on-board flash memory so that it will be loaded at startup, see Downloading an FPGA VI to the Flash Memory of an FPGA Target.
I'm not sure what you're asking here.  Within your LabVIEW program you specifically load a bitfile onto the FPGA and run it.  You can also stop the FPGA and load a new bitfile within the same host application - this is useful when you want to accomplish several non-overlapping tasks on the FPGA and there isn't enough space to fit all of them in the same design.
See "Using LabVIEW FPGA Interface without the FPGA Module."  When you headlessly, do you mean with no LabVIEW application running at the same time, or something else?
There are LabVIEW FPGA method nodes to abort and reset the FPGA, so you could write a simple LabVIEW application to do this.  I cannot say that's the only way, but it's the only one I know.  I don't know of any way to clear the FPGA without a power cycle, but the reset method might be close enough.
(3,534 Views)
Thank!
(3,517 Views)
