fpga pwm signal falling edge problem
Hi all,
I have a problem with my pwm signal. I generate pwm signal with NI 9475 on cRio.
If you have any idea please share with me.
Thanks!
gulyvz
code hereby enclosed.
(3,336 Views)
Hi gulyvz,
according to the manual the NI9475 is a sourcing DO module.
I have a problem…
What's the problem? Blurry images?
I guess the picture shows the voltage vs. time and you speak about the falling edges: is there any capacitor (or low pass) connected at the DO?
What did you connect to the module? Can you supply schematics?
(3,319 Views)
Hi GerdW,
I have a problem with square signal falling edge. I want to generate square signal which duty cycle adjustable.
I hope it will be clear.
gulyvz
(3,314 Views)
