fpga target VI won't compile
Accepted by topic author FG_2001
I would say that's progress (you should always be able to connect to localhost:3580/3582).
This points back to the initial permissions error though, if you manually browse to that file does it exist?
If so is it set to read only? Is the folder set to read only?
Craig H. | CLA CTA CLED | Applications Engineer | NI Employee 2012-2023
Message 11 of 12
(1,743 Views)
All files in the directory were set to r/w permissions.
However, the folder was set to read only!
D'oh! Smiley Embarassed
After changing the permissions on the folder I've successfully compiled.
Thanks for the help.
Message 12 of 12
(1,735 Views)
