fpga to generate pulse train and counter
I have some experience with Quartus, but new to the NI FPGA.
I have a PCI-7811R. I am trying to use it to sequentially light up 144 LEDs repetitively. The period of each pulse is 480us.
Basically, I need to generate a pulse generator and a counter to record the pulse number, and according to this number, select which LED is on.
I designed a pulse train generator based on a example from FPGA help, and added a counter in it. You can see it in the attached vi.
My question is,
When I put the I/O node inside the single-cycle timed loops, it can generate the correct pulse.  However, when I tried to use the local variable to transfer data out of the SCTL, and then connect it to another I/O node, I cannot detect the pulse signal when I measured this I/O.
Is there something wrong with my code when I try to transfer data out of the SCTL? Can I also use local variable to transfer the counter value, because I will need it in the following part.
Thank you!
(3,133 Views)
Accepted by topic author bluerunner
If you're referring to the local variable wired to DIO2 in your attached VI, the problem is very simple: it's outside a loop, so it only executes once.  Put that local variable and the IO node in a loop and I think you'll get something close to the pulse you expect (although if it's not in a single-cycle loop you may not get exactly the same timing).
(3,126 Views)
