03-31-2009 11:06 AM
Hi I have a question about a FPGA vi. I try to create a bit pattern 0-7 and give at the dio output on my FPGA Card. The first 7 pattern should have a duration of 2 us and the last pattern should have a duration of 6 us. For this I use a loop timer in a for loop. If I say I want all pattern to have the same duration this works fine. For the other solution I made two for loops each with own loop timer, but this doesn't work properly. Is it allowed to use several loop timer?? Or has anyone another idea how to solve this Problem??
Thanks...
03-31-2009 11:35 AM
04-01-2009 02:58 AM
Just a quick addition: Using array constants on an FPGA wastes a lot of gates. For better FPGA usage you should try to avoid arrays as much as possible (e. g. by using the onboard memory or by calculating values on the fly).
Jochen
04-01-2009 03:29 AM
Hi
with the time array it works fine.
Jochen, thank you also for your advise. I'm new working with FPGA programming. Are there some examples using the onborad memory for such a question??
Regards, Irina
04-01-2009
05:58 AM
- last edited on
09-19-2026
02:04 PM
by
Content Cleaner
Hi Irina,
for a small amount of data an array is not critical, but if you plan to use more data or if your FPGA runs really low of gates, you should consider using block memory access.
Here is a tutorial that covers this topic. An example is attached at the bottom of the document.
Kind regards,
Jochen Klier
