fpga
I want to tell me  if it is allowed to use a FPGA I/O nodes in Single-Cycle timed loop ? if the answer is "yes", how does  this node work inside timed loop if this
node contains a VHDL code (sequential and combinatorial) ?
(3,738 Views)
and if it is allowed to use a FIFO in Single-Cycle timed loop ??
(3,737 Views)
You can use FPGA I/O nodes in single cycle timed loops, with limitations:
https://www.ni.com/docs/en-US/bundle/labview-fpga-module/page/using-single-cycle-timed-loops-to-opti...
You can use FIFO-s in single sycle timed loops for sure. In fact, you can use it between them for passing data, I would recommend them as the solution for crossing clock domains:
https://www.ni.com/docs/en-US/bundle/labview-fpga-module/page/implementing-multiple-clock-domains-fp...
For using VHDL code in a single sycle timed loops, it can only contain combinatorial logic. If you have sequential logic, you will get an error message after the compilation
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P8sWSAS&l=en-US
Best Regards,
Simon
Best Regards,
T Simon
Certified LabVIEW Developer - Certified TestStand Architect
(3,718 Views)
my code is sequential logic, so what is the method to implement my code inside timed loop using CLIP? what is the result if I put my code inside while loop ??
(3,710 Views)
Accepted by topic author mahmoud12
You can cut your code to pure combinatorial sections by rplacing your registers with LabVIEW "shift registers" on the single cycle timed loop. This way you basically implement pipelined logic.
Optimizing your LabVIEW FPGA VIs: Parallel Execution and Pipelining
You can find help about using CLIP nodes in these articles:
Importing External IP Into LabVIEW FPGA
Simon
Best Regards,
T Simon
(3,699 Views)
