fpga
I am a new user of FPGA and Lab View ....i have to read output of a hall sensor......actual output is 2.5 V .. when i connect the output of hall sensor to pxi-7842R via scb 68 I get some raw data like 8160...can any one tell me how to convert it to a fixed value..i tried to do it via link given below but i am not able to do it..please help
http://digital.ni.com/public.nsf/allkb/BBBD1A290BDDBF50862575AE0006124C?OpenDocument
(2,906 Views)
Hi Gaks
Could you please upload your VI so that I can understand better what you're doing? Would you like to read the actual voltage i.e. 2.5v? Do you know if your raw data is linearly related to the actual output?
Kind Regards
Chris | Applications Engineer NIUK
(2,867 Views)
There is no need to open up 2 threads for the exact same problem.
http://forums.ni.com/t5/LabVIEW/fpga/td-p/2182164
(2,860 Views)
hey chris i have got the solution ..thanks
(2,852 Views)
