fpsane.cpp
After changing the History chart length in waveform chart and trying to save the vi, an error message popped up and it reads as follows,
Fatal Internal Error: "fpsane.cpp", line 397
LabView 8.0
Can anyone tell me what the problem is?
Message 1 of 12
(7,122 Views)
I think that fpsane.cpp does a sanity check on the front panel items.  The quickest way to fix errors like this is to remove the control or indicator and re-create it.  Often merely replacing it will not fix it.
What is happening is that something has gone wrong with the control/indicator and it is throwing an unhandled insanity error.
I hope that this helps,
Bob Young
Message 2 of 12
(7,118 Views)
Hi, hellolv.
Bob is right. An fpsane error usually means something has become corrupt in the front panel somehow. If you can reproduce this error consistently and feel comfortable posting your code, I'd like to file a report on it to R&D so it can be fixed in a future version of LabVIEW.
Have a nice evening!
Sarah K.
Search PME
Message 3 of 12
(7,109 Views)
Hello.
An error was created while it worked in the frontal panel and I do not know to that it must.
I cannot modify and it does not allow to keep no change, single I can runs the application.
Fatal Internal Error: “fpsane.cpp”, line 392
LabVIEW version 8.2
You will lose any unsaved work.
Thanks.
Gustavo
Message 4 of 12
(6,812 Views)
Hello Gustavo,
T
his internal error was reported to R&D (# 41I2H99 & # 44QAJDG0) for further investigation.
Any additional information that you can provide to us would be helpful, including the VI that caused the error as well as the error log file.
Thanks for the feedback!
Kameralina
Message 5 of 12
(6,789 Views)
I also get this error, which is totally annoying.
I am currently working with some classes into a shared variable. After I add the variable to to routine, the LabView becomes really slow and crashes finally with the mentioned error.
This bug seriously hampers my development progress!
Bart
Logfile:
#Date: 2008 Feb 19 10:27:30 AM
#OSName: Windows NT
#OSVers: 5.1
#AppName: LabVIEW
#Version: 8.2
#AppKind: FDS
#AppModDate: 07/27/2006 11:08 GMT
.\diagram\proptype.cpp(306) : DWarn: typeprop caused typeprop a third time! give up
$Id: //labview/branches/Europa/dev/source/diagram/proptype.cpp#79 $
0x0080305A - LabVIEW <unknown> + 0
0x00D128A8 - LabVIEW <unknown> + 0
0x00D13E4A - LabVIEW <unknown> + 0
0x00C2AA85 - LabVIEW <unknown> + 0
0x00F31429 - LabVIEW <unknown> + 0
0x00F72B79 - LabVIEW <unknown> + 0
0x0123EF6B - LabVIEW <unknown> + 0
0x055D6CA4 - lvMax <unknown> + 0
0x0559CF80 - lvMax <unknown> + 0
0x748B560C - <unknown> <unknown> + 0
*** Dumping Bread Crumb Stack ***
Loading Z:\bart\LabVIEW\projects\CDM waveform monitor\1.05 LV8.2\Main window 800x600.vi
*** End Dump ***
0x006C03F6 - LabVIEW <unknown> + 0
0x006C01C2 - LabVIEW <unknown> + 0
0x006C06CC - LabVIEW <unknown> + 0
0x00C38C46 - LabVIEW <unknown> + 0
0x00C48ADE - LabVIEW <unknown> + 0
0x00C497C6 - LabVIEW <unknown> + 0
0x004CCB39 - LabVIEW <unknown> + 0
0x004D7C95 - LabVIEW <unknown> + 0
0x004DAF97 - LabVIEW <unknown> + 0
0x004E10B1 - LabVIEW <unknown> + 0
0x00C14A89 - LabVIEW <unknown> + 0
0x00C14C90 - LabVIEW <unknown> + 0
0x00C172E6 - LabVIEW <unknown> + 0
0x008032EF - LabVIEW <unknown> + 0
*** End Dump ***
0x006C070A - LabVIEW <unknown> + 0
0x00B7BA47 - LabVIEW <unknown> + 0
0x00CA8CCF - LabVIEW <unknown> + 0
0x006C055A - LabVIEW <unknown> + 0
*** End Dump ***
0x00C14B7B - LabVIEW <unknown> + 0
*** End Dump ***
0x00B7BA5D - LabVIEW <unknown> + 0
0x00803579 - LabVIEW <unknown> + 0
*** End Dump ***
0x00CAA12C - LabVIEW <unknown> + 0
0x00CA8FA3 - LabVIEW <unknown> + 0
0x00CA9515 - LabVIEW <unknown> + 0
0x00CA9F42 - LabVIEW <unknown> + 0
0x00D13F2F - LabVIEW <unknown> + 0
.\typedesc\TDOMIdRefnum.cpp(1373) : DWarn: Insane dataspace: contexts do not match for udclass type at data=0x08f820f0
$Id: //labview/branches/Europa/dev/source/typedesc/TDOMIdRefnum.cpp#23 $
0x00501B06 - LabVIEW <unknown> + 0
0x0050339B - LabVIEW <unknown> + 0
0x0112DFDA - LabVIEW <unknown> + 0
0x010C452B - LabVIEW <unknown> + 0
0x00C501E2 - LabVIEW <unknown> + 0
0x0076BB5A - LabVIEW <unknown> + 0
0x0076FCD9 - LabVIEW <unknown> + 0
0x00C05721 - LabVIEW <unknown> + 0
0x0076CFE5 - LabVIEW <unknown> + 0
0x0076CD42 - LabVIEW <unknown> + 0
0x007707DC - LabVIEW <unknown> + 0
0x00CA9A5E - LabVIEW <unknown> + 0
0x00CAA33B - LabVIEW <unknown> + 0
sanity checking heap Z:\bart\LabVIEW\projects\CDM waveform monitor\1.05 LV8.2\Main window 800x600.vi
sanity checking Z:\bart\LabVIEW\projects\CDM waveform monitor\1.05 LV8.2\Main window 800x600.vi
*** End Dump ***
Insane object at FPHP+10C in "Main window 800x600.vi": {dso } (0x200): Panel (FPSC)
.\panel\fpsane.cpp(392) : DAbort: Fatal insanities(0x200) exist in ReportInsanities, 'Main window 800x600.vi'
$Id: //labview/branches/Europa/dev/source/panel/fpsane.cpp#35 $
0x0076CEF3 - LabVIEW <unknown> + 0
*** End Dump ***
Message Edited by Bart_NLD on 02-19-2008 03:37 AM
Message 6 of 12
(6,763 Views)
Hello Bart,
It is much easier for us to follow up effectively on internal errors when they are sent to us through e-mail.
You can reopen your error log in LabVIEW by selecting Help » Investigate Internal Error... and then you can select Investigate and
Any additional information that you can provide to us would be helpful for us to reproduce the error, such as the VI you were working with.
Message Edited by FieldKam on 02-20-2008 10:43 AM
Kameralina
Message 7 of 12
(6,728 Views)
Hi FieldKam,
Thanks for your quick reply.
I reported this issue by phone at NI Netherlands yesterday. As far as I understood, they found the report here sufficient.
I have a temporary workaround that seems to hold:
  • I created a variant shared variable, together with 2 read and write VI's.
  • In the read VI, I do an explicit type conversion to the class that I use
  • In the write VI, I explicitly convert the object to a variant.
Maybe this helps for others too?
Bart
Message Edited by Bart_NLD on 02-20-2008 10:56 AM
Message 8 of 12
(6,720 Views)
Hi Bart,
Thank you for your reply and for posting your workaround for others!
I have already reported this error to R&D, and NI Netherlands will be doing the same.
R&D has informed me that they will need the following file from you to aid their investigation of this error:
Would it be possible for you to provide this to us?
Kameralina
Message 9 of 12
(6,574 Views)
Hi FieldKam,
Do you only need this file? It ia part of a (possible) proprietary project. With or without the workaround in it.
Bart
Message 10 of 12
(6,554 Views)
