fractional sting to decimal number conversion
Hi!
I want to convert my fractional string to number in the following format. I want to restrict number after 3 decimal. Can anybody help.
My fractional string - 123.456789 i want number - 123.456
- 12.123456 - 12.123
- 123456.123456 - 123456.123
Kaustubh
VC (Pune)
INDIA
(3,125 Views)
Hello Kaustubh,
just convert string to number using "Scan from String" and then round your number (multiply by 1000, round to nearest, divide by 1000).
Perhaps the formatting of the output indicator may help: just show the number with only 3 decimals after the point.
(3,118 Views)
You can scan from string to a float and then convert it back to a string using %.3f this will return a string with 3 digits of percision after the decimal point independent of howmany it started with or you can parse the string and shorten it (remember that \. is needed to recognize the decimal in a regular expression).
Paul
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(3,098 Views)
Check this out 🙂
The attached VI allows # of decimal point control
Cheers!
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
(3,087 Views)
Thanks Ian F K
It works.
Thank You
Kaustubh
VC (Pune)
INDIA
(3,082 Views)
You're most welcome 🙂
Alternatively, you may also thank us by rating our replies, as it let us know to what extend that our replies help 🙂
Cheers!
Ian F
依恩与LabVIEW
(3,078 Views)
