frequency measurement FP-CTR502
I am trying to measure the frequency of a pulse signal coming into my FP-CTR502.  I know I can conncect it to a gate, and then using a reference 32k or 1k signal on another channel, determine reference counts/time.  But I am limited on inputs and would like to see if there is a way I can directly read it on one channel.  The only way I have been able to do this is read the counter, and then shorlty there after read the counter again and counts/time again, but I would like more accuracy especially with a slow freq (800RPM with a 1-2s sample rate).   From what I understand, Diadem offers a module that reads it directly from the input.  Is there something similar in Labview?
thanks,
C
(2,554 Views)
Hi C,
There are three methods that you can use to measure the frequency with the FieldPoint Counter modules. This knowledgebase thoroughly describes the first two methods and has some helpful links: How Can I Measure Frequency With the FP-CTR-500/502?
The third method is to simply use a single counter to find the number of pulses over a period of time. If you need higher accuracy than this method, then I recommend using one of the two methods described in the knowledgebase.
Hal L.
(2,536 Views)
Thanks Hal,
I looked at that link and it involves using the gate also.  I am trying to avoid that, and I was hoping there was more functionality to the CTR that I didn't know about.  There was a Diadem block that I thought read the frequency directly but it was really a script just performing the same type of counts/time calculations.  I think I have it figured out so that I can just use the one input and then I will average my results, it will be a little slow to quick changes but should give me a bit more stable data.
thanks again
C
(2,527 Views)
