frequency spacing
Dear All,
I am acquiring analog signal and I am using 'filtering' , 'tone measurements' , 'fft' express vi's.
I realized that fft found a peak frequency of a value which is 1000 times lower than the actual frequency. In my vi sampling rate is 1000 Hz, number of samples to be acquired is 1000. Looking at the attached example  I figured out that I need the frequency spacing information.
Using 'build cluster' I merged FFT output with sampling rate and resulting plot looked correct.
But this does not solve my problem, since I need to have the dynamic data stream to be 'correct'. I need to find the frequency of a different signal using 'tone measurements' express vi which currently is giving a 1000 times lower value . I also want to use filtering vi, which does work properly under this condition.
Any suggestion will be more than appreciated.
ilter
(3,632 Views)
ilter <x@no.email> wrote in news:1146582612618-359556@exchange.ni.com:
> Dear All,
> measurements' , 'fft' express vi's.I realized that fft found a peak
> acquired is 1000. Looking at&nbsp;the
> attached&nbsp;example&nbsp;&nbsp;I figured out that I need the
> frequency spacing information. Using 'build cluster' I merged FFT
> output with sampling rate and resulting plot looked correct.But this
> work properly under this condition. Any suggestion will be more than
> appreciated. Regards,
> ilter
> fft.JPG:
> http://forums.ni.com/attachments/ni/170/182552/1/fft.JPG
Since you sample rate is 1K, and you're getting a max at a frequency 1000X
less than you would think, you must be getting a max at .3Hz or less, I
would imagine.
Subtract the mean from your signal before taking the fft. Better yet, fit
the whole data set to a line, and then subtract out that line, and take the
fft.
Scott
Reverse name to reply
(3,622 Views)
Duplicate Post
Ed Dickens - Certified LabVIEW Architect
Lockheed Martin Space
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
(3,614 Views)
