01-22-2014 03:44 AM
I'm working with an old project... It has some VIs on PC and someothers on the FPGA of a cRIO. I started it in LV 8.5 and now I have it on LV 2011.
I have to fix a bug an so I do it... but when I have to install it on the customer's PC I cannot do it. I was able to create the exe file and the installer. I installed it on the customer's PC, but when I try to run it he is asking me the NiFpgaLV.dll file.
So I decided to migrate the project in LV 2013. If I try to compile the FPGA VI it didn't work.
Please, find attach the XilinxLog file.
01-22-2014 04:20 AM
Hy,
can you upload a screenshot from the compiler window, where the error is shown.
01-22-2014 04:22 AM - edited 01-22-2014 04:24 AM
Design Summary:
Number of errors: 1
Number of warnings: 85
Logic Utilization:
Number of Slice Flip Flops: 17,346 out of 28,672 60%
Number of 4 input LUTs: 34,092 out of 28,672 118% (OVERMAPPED)
Logic Distribution:
Number of occupied Slices: 18,106 out of 14,336 126% (OVERMAPPED)
Number of Slices containing only related logic: 14,451 out of 18,106 79%
Number of Slices containing unrelated logic: 3,655 out of 18,106 20%
*See NOTES below for an explanation of the effects of unrelated logic.
Total Number of 4 input LUTs: 35,997 out of 28,672 125% (OVERMAPPED)
Number used as logic: 34,069
Number used as a route-thru: 1,905
Number used as 16x1 RAMs: 16
Number used as Shift registers: 7
Number of bonded IOBs: 117 out of 484 24%
IOB Flip Flops: 70
Number of RAMB16s: 91 out of 96 94%
Number of MULT18X18s: 23 out of 96 23%
Number of BUFGMUXs: 3 out of 16 18%
Number of DCMs: 1 out of 12 8%
