from one array to another
I have an array which produces random numbers and pass this list to another array. How can I select the numbers  from the first array, so that only 1 every let's say 5 goes to the second array? Thanks,
P.S Here attached is the VI
(2,918 Views)
The simplest way is to use Decimate 1D Array. You can expand this node so that it creates 5 output arrays. The first output will be every 5th element of the input array, starting with the first.
Message Edited by Marc A on 10-11-2007 09:02 AM
(2,910 Views)
Thanks a lot Mark!
Valter
(2,903 Views)
