from string to block diagram
I need to know how you can translate a string, a formula, to the block diagram. So for instance, if you have G=5+3*lnW, how can you translate the ln to the ln in the block diagram. The formula isn't fixed so I can't make a hard code.
Thanks in advance
KF_
Message 1 of 8
(3,985 Views)
edit: oops didn't see that the formula always changes
Bill
CLD
(Mid-Level minion.)
Message 2 of 8
(3,980 Views)
The goal is that I can give in the formula in the front panel, not in the block diagram like the formula node
Message 3 of 8
(3,973 Views)
Check this out, my friend:
http://zone.ni.com/reference/en-XX/help/371361G-01/gmath/advanced_formula_vis/
Smiley Happy
http://www.medicollector.com
Message 4 of 8
(3,968 Views)
That's great - I just learned something new!
Bill
CLD
(Mid-Level minion.)
Message 5 of 8
(3,963 Views)
You would need to write a parser that would evaluate the equation entered. If you use RPN this is fairly easy to do. RPN is nice since it lends itself well to using a stack for processing the equation and you will always be dealing no more than the top two elements of the stack. Your evaluation routine would be in a loop that would parse the equation and invoke the proper case in a simple state machine. You will need to use a shift register to store the variables, operations and intermediate results as you parse the equation. You would need a case for each operation you will support.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 6 of 8
(3,962 Views)
Ok, these comments should help me enough, cheers
Message 7 of 8
(3,950 Views)
Is Python an option?  Look at this example I posted (a few years ago - wow) using LabPython.
Jim
Message 8 of 8
(3,917 Views)
