front panel background
And pressing OK does not change the background?
Is that limited to this specific VI? Or is it for all VIs.
What happens if you transfer a VI with modified background to that machine?
Norbert
Norbert
Expert: Geometry
Message 11 of 13
(1,007 Views)
Norbert
Correct. Pressing OK does not change the background.
This occurs in all vi's. Two different machines.
I have not been able to change the background so I have no examples to show you. I have been using the pane property node as a workaround.
This is not a show-stopper. However, it seems that over the years front panel properties (size, center, background image, etc) have slowly been losing functionality if set via the front panel UI. I'm always left with resorting to hard-wiring with properties in the block diagram. Maybe it's something I'm doing or running in the background but can't think of anything off the top of my head.
PaulG.
Retired
Message 12 of 13
(982 Views)
If you still can use that dialog window to change the pane Appearance, then this VI has problem:
C:\Program Files (x86)\National Instruments\LabVIEW 2013\resource\PropertyPages\Pages\PropPage_PaneBackground.vi
George Zou
Message 13 of 13
(973 Views)
