front panel cosmetic change
Hello!
Attached please find a sample vi. On page 2 and page 5 you can see some boxes and faint lines. I am wondering if it is possible to change its size, and how can i create more?
Thank you so much for your generous help!
(3,755 Views)
I'm unable to open the VI (size 13 KB).
(3,750 Views)
I can open the VI but those elements seem to be ghosts.
LabVIEW is drawing them but they do not seem to be tied to anything (cant left or right click on them to select).
You can select them by performing a selection rectangle but even when selected you cant delete or move them.
No right click menus.
I would say they used to be decorations but someone tried to delete them and only half suceeded
(3,742 Views)
Oh! I don't know why I am able to open it!
Anyway try this one!
(3,739 Views)
Accepted by topic author coolmatthew
Oops, my bad, LabVIEW was "stuck".  A logoff/logon fixed it.
I have no idea how you got those lines to appear on your Tab.  Do you know about Decorations (found on the Front Panel palette, but not on the Silver Palette -- try the Modern Palette).  The Raised Frame might be what you are looking for, very visible ...
BS
(3,736 Views)
Oh I see! Thank you very much for your prompt reply!
I am wondering if there is anyway to draw similar rectangles or produce similar "ghosts" like them?
(3,733 Views)
Oh I found it now! That is exactly what I wanted!
Thank you so much!!! Heart
(3,728 Views)
