front panel dll on top
I made a dll using Labview 2009 64bit.
It is called by an other application written in C#.
The first time it opens on top of the window of the C# program.
When it is called a second time it is behind this main window.
How can I keep my front panel of the dll always on top??
I tried setting the option model in window appearance, this frooze the main window and the front panel was still behind it.
thanks!
kim
Message 1 of 8
(3,518 Views)
Inside the LabVIEW code, use the Front Panel "Open" method (through an Invoke node) to activate the appropriate front panel on each call to the DLL.
Message 2 of 8
(3,508 Views)
Message 3 of 8
(3,499 Views)
sorry, forget remark
Message 4 of 8
(3,496 Views)
Thanks for you reply, but unfortunately this doesn't work for me.
The front panel is open, but behind the main application.
I should be able to put it on top of all applications...
Message 5 of 8
(3,486 Views)
Accepted by topic author KimT
Sorry for misleading you, then - I didn't try this in a DLL prior to posting.  How about the Application method "Bring to Front"?  Does that work for you?
EDIT: and if that doesn't work, try the Windows calls suggested in this post: http://forums.ni.com/t5/LabVIEW/Bring-LabVIEW-built-exe-to-front-on-subsequent-launch-attempts/m-p/2...
Message 6 of 8
(3,477 Views)
I think it might be a windows 7 issue...
Message 7 of 8
(3,448 Views)
the links helped!
thanks for the help.
Kim
Message 8 of 8
(3,441 Views)
