front panel doesn't print
It has been exactly the same.....the only thing I changed was the background color....As soon as I changed it the Front panel stopped printing properly. I have tried to revert back to the default background but it doesn't change on the printout.
Message 11 of 18
(1,013 Views)
Hmmm, Try this.  Print as usual but when the print dialog reaches the Destination selection, select HTML file.  Then print to the html file in a directory that you create to hold it.  If the picture of the front panel is the same, (no controls) then we know that the problem is with LabVIEW, if it is not the same, then it points at the printer driver or similar.
Jon D
Certified LabVIEW Developer.
Message 12 of 18
(997 Views)
I printed to an HTML file and when I opened the file it looked like I created it. I printed it to the same printer and it came out fine.
Message 13 of 18
(991 Views)
Do you mean that you printed the html version to a printer and it came out fine, or when you printed the vi to a printer the problem had been fixed?
Jon D
Message 14 of 18
(980 Views)
When I printed the HTML file it printed fine. It will not print properly from LabVIEW
Message 15 of 18
(970 Views)
I have tried printing other VI's and the front panel prints fine.
Message 16 of 18
(955 Views)
Hrm, Not sure what the problem/fix is then sorry. 😞
Jon D
Message 17 of 18
(937 Views)
That is ok....I just wanted to find out if anyone else had run into the same issue.....Thanks for your help
Chris
Message 18 of 18
(935 Views)
