front panel intact block diagram lost
Not really sure what happened.  Was working on some code, everything was fine except the computer was running a little slow, so I switched to a different computer to finish it.  Finished it fine so I went back to original computer to run a test, it's the only computer with the right hardware for running the test, and the front panel is fine, but it will no longer let me pull up the block diagram:
VI errors:
The VI has a bad connection to or can't find a subVI or external routine but it has no block diagram to show or fix the error.  You must find or correct the subVI or external routine.  Check for more information in the explain dialog box in Get Info.
I know what subVI it is referring to but I manually fix it and it still does not give me back my block diagram (the error doesn't even think the missing block diagram is a problem), and I have used two different computers before and never had this happen.  I have tested other programs and older versions of my program and they all show a block diagram fine.  I would like to find a solution other then going back to an older version and doing it all again but I have no idea what to do to fix this.  Please help!
(3,135 Views)
I also get another error if I try to click on VI icon or try to do other random things (such as moving one of my tables):
Fatal Internal Error
'transact.cpp' line 522
LabVIEW 8.6.1
(3,110 Views)
Hi EAims,
I see you are working with Tej on this over email. When he comes up with an applicable answer we will post it on here.
thanks
FLash
(3,092 Views)
Ok thanks!
(3,089 Views)
