front panel objects move
I save my VI. When I reopen it some of the objects have moved. This is in version 8.0. Attached is the VI, if you move the horizontal central orange line vertically up about 6 grid squares, to connect the two vertical orange lines, then save. When I reopen, it has moved. I have tried to lock it in position with the reorder options, but no effect.
(3,033 Views)
LV 8.0 has a lot of problems in positioning Front Panel and Block Diagram objects after save and open.
You should really update.
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
(3,023 Views)
Hi there,
Just to back up what Waldemar has said:
I've run a search through the achive of past queries and found that this was a known problem with the LabVIEW 8 series, to which a solution was not found before LabVIEW 2009 was released. Having not encountered this issue in any later versions of LabVIEW I'm afraid I can only recommend an upgrade.
Best of luck with your application.
Rhys
(2,993 Views)
