HI,
I'm working with 6.1. But this makes not really a difference. I did already a small example VI quite similar to the VI that you have posted. There I havn't had that problem, too. But in the big main programme I do get those problems. In that programme there is a Case structure. In one case I have an Event structure. In the other case I have the SubVI that I'm calling. Somehow it seems that the Event structure even it should not be involved at all interferes with the rest of the program and locks the event structure (there is one event which is triggered from the same button as from which I want to stop the subVI).
That is only a guess from my side. Could that be a problem?
ANDY
