front panel refresh
Hi! I have a problemi with a VI that acquires and writes signals on a cFP-2010 module.
I created a small subVI that lets me see when the values of pressures from 2 different transducers are equal.
(I took a snapshot, it's named "pressures"). Then, I have to open/close some valves according to the values of the signals.
I would like to do so with a case structure, so I thought of creating a boolean array, converting it to a number and use that
as the case selector of the case structures. Before doing that, I wrote a subVI that lets me se which number corresponds to each case
(it's the jpeg named boolean array).
However, as I put it in the main VI, I experienced a problem: the VI acquires data every 4 seconds instead of 1 (which is the time of execution
of the while cycle of the main VI, which I set by using a "wait until next ms" function.
Where is the problem?
Thank you in advance for your help!
(2,952 Views)
Hello Turillo,
to understad it better could you attach your main VI?
I think that the problema should be there.
Thank you,
Valerio
(2,858 Views)
Sure Valerio,
here it is...Unfortunately, it's made up of quite a lot of subVIs...
Anyway, I hope attaching it could help... 🙂
(2,815 Views)
