front panel saving
Hey i got a graph , few indicators and controls assocaited with my program to log data.
After my test is done can i save  my front panel to a file so that i can reopen it with all parameters and graphs being dislayed???are there such setting or any other way ?
Best regards
SDI
(2,930 Views)
Hi sdi,
there's an "invoke node"-method "Get Panel Image" that gives you all data needed to save a picture using one of the "write picture file" functions.
You can also make your own routine to save the values of all controls/indicators in Configuration files (there are many threads on this topic here in the forum).
(2,926 Views)
Hi ssddii
you can use "make current values default", but to do it you have to write a second vi which calls the method, because as far as i know the vi which values you want to make as default can´t call this method itself. Another way is to write all control values into an ini file.
Mike
(2,925 Views)
