front panel snap shot
Hi all,
can some body tell me how to take the snap shot of the front panel as a whole to be used in an html report.
I was able to take the snap shot of a single waveform and attach it to a report...But to take the whole front panel how can i do it??Is it possible??
Stephen.
(3,195 Views)
This is the VI that i built it works fine but i want to take the full snap shot of the front panel
(3,194 Views)
I think there is a method called 'Get Front Panel Image' available, which will do your job.
- Partha ( CLD until Oct 2027 🙂 )
(3,187 Views)
The Code Capture Tool does just that. You can use the subVIs that are used to capture the front panel and save it to file.
(3,173 Views)
