front panel
How do we do this in labview:
> press a button on front panel which says "START" and a new window on the front panel shows up which has 5 lines. When you click one of the lines it takes you to new front panel or blank front panel.
(3,887 Views)
Hi Miaa,
what do you mean with "a new window on the front panel shows up"? And what do you mean with 5 lines? Can you explain please, or have you a picture of it?
Mike
(3,886 Views)
Hello MikeS81,
Attached is the document which explains the objective. on the same front panel when i click the START button it should give me a new layout of front panel which will have three button "step1, step2, step3". and this front panel screen will no longer have the START button.
Really appreciate your reply ....
(3,861 Views)
Hi Mia,
like this? See the attached example please.
Mike
(3,847 Views)
Just fixed a minor thing. The initial start button was no visible when the VI first started.
Eli S.
(3,828 Views)
Thanks Eli
Mike
(3,825 Views)
