front
when object #2 is active, i want to the others are passive.
when object #4 is active, i want to the others are passive.
i want to selected object in the front panel is active, the others are passive
Message 1 of 8
(4,462 Views)
Please define what you mean by "active" and "passive". Are you referring to disabled? Disabled and greyed out? Visible?
Message 2 of 8
(4,458 Views)
yes, it is like disable options. for example when the selected object rotates by pushing a button, the other objects or boxes are not affected. then when i select the other object (box #2), i want to box #3, #4,.. etc. are not affected.
Thanks!
~drycsr~
Message 3 of 8
(4,448 Views)
I'm sorry, but your explanation is not clear. Now you're talking about rotating. Your screenshot seems to show what might be a picture indicator? Are you drawing these boxes? Can you post your VI?
Message 4 of 8
(4,424 Views)
Message 5 of 8
(4,407 Views)
rotating is just an example to explain what i want. shortly, we want to the selected object in the front panel is active, the others are passive. thank you!
Thanks!
~drycsr~
Message 6 of 8
(4,369 Views)
You have way too many loops and event structures. You only need one loop and one event structure. You can use the Disabled property for the controls to simply disable the ones you want based on your conditions.
Message 7 of 8
(4,349 Views)
This discussion has moved here.
Message 8 of 8
(4,254 Views)
