fsolve don't work
Hello.
I have a problem with fsolve function. can u help me please?
I think that fsolve function should be work correctly in mathscript node, but I cant use it in my math script node code. this is my code that correctly work in MATLAB:
x0=[150;.00001;1.5];
x1=zeros(Npump,3);
%% make pump curve
for ii=1:Npump
    kk=0;
    QH=zeros(1,3);
    HQ=zeros(1,3);
    for jj=1:2:6
        kk=kk+1;
        QH(kk)=DisQH(ii,jj);
        HQ(kk)=DisQH(ii,jj+1);
    end
    save Q QH
    save H HQ
    x1(ii,:)=fsolve(@pumpcurve,x0);
end
can u help TO find problem?
(4,269 Views)
Code snippet of your runnable VI?
(4,264 Views)
excuse me ToeCutter, I dont understand your mean. this is a part of my code that I have problem with. my code is perform except this part
(4,260 Views)
Hi behzad,
error codes? Error messages? What do you get?
(4,254 Views)
fsolve() uses Optimization Toolbox. LabVIEW's MathScript does not load toolboxes. You may think about finding the files required for running fsolve() and copying them into your working directory.
Check out some other threads: http://forums.ni.com/t5/LabVIEW/Calling-MATLAB-SOAP-From-MathScript/m-p/1237926/highlight/true#M5241...
(4,244 Views)
thanks a lot ghighuphu. I'll try your suggestion. is any function for nonlinear equation instead of Fsolve?
Hi GerdW, thank u too.
(4,204 Views)
Have you tried searching in the functions palette for "nonlinear?"  The search function is how I got around the various palettes until I learned where most of the stuff was.  🙂
Bill
CLD
(Mid-Level minion.)
(4,197 Views)
