full programme posted!! unable to read the frequency
my programe reads in off an lvdt transducer through a labjack my programe works up until the LJ stream graph process reads to "scaled data v's seconds" graph.where it graphs a sin wave (amplitude vs time)
for some reason the "freq. amp." analyser won't read the frequency correctly. when i run the programme it outputs a frequency of zero.
note: the amplitude is reading correctly
At the end i am looking to have a point on the x-y graph. it is the the output needed for my project.
note: everything works upuntil the scaled data V'S seconds graph
(2,551 Views)
The subvi that produces the output for the "Scaled Data vs Seconds" is not available from your upload--it appears to be your problem.
I attached a jpeg of a test I ran on the last part of your vi--it should work successfully. The simulated signal correctly produces a point on the X-Y graph for amplitude and frequency which is what you desire I believe. If you can find the problem in "LJstream graph process.vi" the output part should work correctly.
(2,551 Views)
